Zum Hauptinhalt wechseln
Afterglow Wireless PS3 Controller Vibration Motor Replacement
Was du brauchst
  1. Afterglow Wireless PS3 Controller Vibration Motor Replacement, Back Cover: Schritt 1, Bild 1 von 2 Afterglow Wireless PS3 Controller Vibration Motor Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
  2. Afterglow Wireless PS3 Controller Vibration Motor Replacement, Vibration Motor: Schritt 2, Bild 1 von 2 Afterglow Wireless PS3 Controller Vibration Motor Replacement, Vibration Motor: Schritt 2, Bild 2 von 2
    • Carefully remove the battery by lifting it straight up from its place.
    • Keep in mind that the red and black battery wires are attached to the motherboard. Handle these with care.
  3. Afterglow Wireless PS3 Controller Vibration Motor Replacement: Schritt 3, Bild 1 von 1
    • Unscrew the four 9mm Phillips #0 screws that are attached to both joy stick control mini-motherboards. There are two screws for each mini-motherboard.
  4. Afterglow Wireless PS3 Controller Vibration Motor Replacement: Schritt 4, Bild 1 von 3 Afterglow Wireless PS3 Controller Vibration Motor Replacement: Schritt 4, Bild 2 von 3 Afterglow Wireless PS3 Controller Vibration Motor Replacement: Schritt 4, Bild 3 von 3
    • Jiggle both joy stick control mini-motherboards out of their holding place.
    • Set aside the mini-motherboards so that the vibration motor wire connections are accessible.
  5. Afterglow Wireless PS3 Controller Vibration Motor Replacement: Schritt 5, Bild 1 von 2 Afterglow Wireless PS3 Controller Vibration Motor Replacement: Schritt 5, Bild 2 von 2
    • Pull both vibration motors straight up from their holding place.
  6. Afterglow Wireless PS3 Controller Vibration Motor Replacement: Schritt 6, Bild 1 von 1
    • Use the soldering tool to heat the solder connecting the red and black vibration motor wires to the motherboard to detach the vibration motors.
    • Use this guide for further details on how to solder.
Abschluss
Natalie Cox
207 Reputation
2 Anleitungen geschrieben
USF Tampa, Team S19-G5, Hoffman Spring 2017 Mitglied von USF Tampa, Team S19-G5, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G5
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 866
