Zum Hauptinhalt wechseln
Air Hog Smash Bots Radio Receiver Replacement
Was du brauchst
  1. Air Hog Smash Bots Radio Receiver Replacement, Batteries: Schritt 1, Bild 1 von 1
    • Using the Phillips #0 screwdriver to remove the 8 mm screw.
  2. Air Hog Smash Bots Radio Receiver Replacement: Schritt 2, Bild 1 von 1
    • Lift and slide the batter cover away from the tab holding it in place at the bottom.
  3. Air Hog Smash Bots Radio Receiver Replacement: Schritt 3, Bild 1 von 1
    • Remove the 3 AAA batteries.
  4. Air Hog Smash Bots Radio Receiver Replacement, External Casing: Schritt 4, Bild 1 von 2 Air Hog Smash Bots Radio Receiver Replacement, External Casing: Schritt 4, Bild 2 von 2
    • Using a Phillip #0 screwdriver to remove the eight 8 mm screws.
  5. Air Hog Smash Bots Radio Receiver Replacement: Schritt 5, Bild 1 von 2 Air Hog Smash Bots Radio Receiver Replacement: Schritt 5, Bild 2 von 2
    • Remove the upper armor of the Smash Bot.
  6. Air Hog Smash Bots Radio Receiver Replacement: Schritt 6, Bild 1 von 1
    • Hold the upper body and slide out the bottom half of the Smash Bot.
    • The motor extends from the lower-body into the upper-body. Be careful to not damage the motor.
  7. Air Hog Smash Bots Radio Receiver Replacement: Schritt 7, Bild 1 von 1
    • Peel back the four decal stickers that hold the front and back of the bot together.
  8. Air Hog Smash Bots Radio Receiver Replacement: Schritt 8, Bild 1 von 2 Air Hog Smash Bots Radio Receiver Replacement: Schritt 8, Bild 2 von 2
    • Use the plastic opening tool to pry the front and back of the lower body apart.
    • Carefully remove the back of the bot from the front.
  9. Air Hog Smash Bots Radio Receiver Replacement, Radio Receiver: Schritt 9, Bild 1 von 2 Air Hog Smash Bots Radio Receiver Replacement, Radio Receiver: Schritt 9, Bild 2 von 2
    • Use the Phillips 0 screwdriver to remove two 4.75mm screws.
  10. Air Hog Smash Bots Radio Receiver Replacement: Schritt 10, Bild 1 von 2 Air Hog Smash Bots Radio Receiver Replacement: Schritt 10, Bild 2 von 2
    • Use the soldering workstation to remove the five wires. Directions on how to solder can be found here.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
IUPUI, Team 1-1, Baechle Spring 2016 Mitglied von IUPUI, Team 1-1, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G1
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 295
