Einleitung
This outline will guide you to replace the radio receiver, if it happens to break will in use. A soldering iron will need to be used for this, directions on how to solder can be found here.
Was du brauchst
Lift and slide the batter cover away from the tab holding it in place at the bottom.
Using a Phillip #0 screwdriver to remove the eight 8 mm screws.
Peel back the four decal stickers that hold the front and back of the bot together.
Use the plastic opening tool to pry the front and back of the lower body apart.
Carefully remove the back of the bot from the front.
Use the soldering workstation to remove the five wires. Directions on how to solder can be found here.
Eine weitere Person hat diese Anleitung absolviert.
