Zum Hauptinhalt wechseln
Alldaymall A88X Battery Replacement
Was du brauchst
  1. Alldaymall A88X Battery Replacement, Alldaymall A88X Back Cover: Schritt 1, Bild 1 von 3 Alldaymall A88X Battery Replacement, Alldaymall A88X Back Cover: Schritt 1, Bild 2 von 3 Alldaymall A88X Battery Replacement, Alldaymall A88X Back Cover: Schritt 1, Bild 3 von 3
    • Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
    • After the panels are separated, watch out for the speaker on the rear panel as it's wire is rather short.
    • When separating the panels keep an eye out for the power button and volume rocker as they can be dislodged.
  2. Alldaymall A88X Battery Replacement: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Grip the speaker from the sides with your fingers or a pair of tweezers and slowly begin to remove it from the rear panel.
    • When removing the speaker, make sure not to disconnect the wires in any way.
    • After the speaker has been removed, place the rear panel aside.
  3. Alldaymall A88X Battery Replacement, Battery: Schritt 3, Bild 1 von 3 Alldaymall A88X Battery Replacement, Battery: Schritt 3, Bild 2 von 3 Alldaymall A88X Battery Replacement, Battery: Schritt 3, Bild 3 von 3
    • Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
    • The tape we are removing covers a number of connections on the motherboard. Be extra careful not to server any of these.
  4. Alldaymall A88X Battery Replacement: Schritt 4, Bild 1 von 3 Alldaymall A88X Battery Replacement: Schritt 4, Bild 2 von 3 Alldaymall A88X Battery Replacement: Schritt 4, Bild 3 von 3
    • Using a nylon spudger, slowly work your way underneath the battery separating it from the panel beneath.
    • After the battery is separated from the panel make sure to place it face down above the tablet itself.
    • Throughout the removal process keep an eye on the battery's wires and make sure they do not break.
  5. Alldaymall A88X Battery Replacement: Schritt 5, Bild 1 von 2 Alldaymall A88X Battery Replacement: Schritt 5, Bild 2 von 2
    • Desolder the wires that connect the battery to the motherboard.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Alex
101 Reputation
1 Anleitung geschrieben
USF Tampa, Team 4-1, Lacy Spring 2016 Mitglied von USF Tampa, Team 4-1, Lacy Spring 2016
USFT-LACY-S16S4G1
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 21
Insgesamt: 1,415
