Einleitung
PREREQUISITE
Was du brauchst
Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
Using a nylon spudger, slowly work your way underneath the battery separating it from the panel beneath.
After the battery is separated from the panel make sure to place it face down above the tablet itself.
Using a pair of tweezers begin to peel the antenna from the metal panel.
Work your way down until the antenna is completely removed.
Using a pair of tweezers remove the tape securing the cameras to the back panel.
Using a pair of tweezers remove the camera assembly from its housing and its receptacles.
Now on the left ribbon cable use a plastic opening tool to pull out the black knobs on both sides of the ribbon cable receptacle.
Using a pair of tweezers remove the ribbon cable from its receptacle.
Using a PH0 screw bit unscrew the three 3mm screws securing the motherboard to the back panel.
Gently pry the brackets holding the touch sensor to the LCD Screen
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
