Zum Hauptinhalt wechseln
Alldaymall A88X Speaker Replacement
Was du brauchst
  1. Alldaymall A88X Speaker Replacement, Alldaymall A88X Back Cover: Schritt 1, Bild 1 von 3 Alldaymall A88X Speaker Replacement, Alldaymall A88X Back Cover: Schritt 1, Bild 2 von 3 Alldaymall A88X Speaker Replacement, Alldaymall A88X Back Cover: Schritt 1, Bild 3 von 3
    • Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
    • After the panels are separated, watch out for the speaker on the rear panel as it's wire is rather short.
    • When separating the panels keep an eye out for the power button and volume rocker as they can be dislodged.
  2. Alldaymall A88X Speaker Replacement: Schritt 2, Bild 1 von 1
    • Grip the speaker from the sides with your fingers or a pair of tweezers and slowly begin to remove it from the rear panel.
    • When removing the speaker, make sure not to disconnect the wires in any way.
    • After the speaker has been removed, place the rear panel aside.
  3. Alldaymall A88X Speaker Replacement, Speaker: Schritt 3, Bild 1 von 3 Alldaymall A88X Speaker Replacement, Speaker: Schritt 3, Bild 2 von 3 Alldaymall A88X Speaker Replacement, Speaker: Schritt 3, Bild 3 von 3
    • Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
    • The tape we are removing covers a number of connections on the motherboard. Be extra careful not to sever any of these.
  4. Alldaymall A88X Speaker Replacement: Schritt 4, Bild 1 von 3 Alldaymall A88X Speaker Replacement: Schritt 4, Bild 2 von 3 Alldaymall A88X Speaker Replacement: Schritt 4, Bild 3 von 3
    • Using a pair of tweezers, begin separating the tape downwards from the back panel.
    • Pull the tape away from the wire bundle beneath.
    • Isolate the wire running from the speaker to the motherboard.
  5. Alldaymall A88X Speaker Replacement: Schritt 5, Bild 1 von 3 Alldaymall A88X Speaker Replacement: Schritt 5, Bild 2 von 3 Alldaymall A88X Speaker Replacement: Schritt 5, Bild 3 von 3
    • Desolder the speaker wires from the motherboard.
Abschluss
Drhaber
985 Reputation
7 Anleitungen geschrieben
USF Tampa, Team 4-1, Lacy Spring 2016 Mitglied von USF Tampa, Team 4-1, Lacy Spring 2016
USFT-LACY-S16S4G1
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 6
Insgesamt: 224
