Zum Hauptinhalt wechseln
Altec Lansing inMotion iM9 Volume and Power Buttons Replacement
Was du brauchst
  1. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement, Battery: Schritt 1, Bild 1 von 1
    • Gently push down on the two tabs at the top of the battery door.
    • While holding them down, slowly pull the door towards you.
  2. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: Schritt 2, Bild 1 von 1
    • Once the door is open, use your hand to pull out the four batteries.
  3. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement, Volume and Power Buttons: Schritt 3, Bild 1 von 2 Altec Lansing inMotion iM9 Volume and Power Buttons Replacement, Volume and Power Buttons: Schritt 3, Bild 2 von 2
    • Pry off the control panel on top of the speaker using the metal spudger. You may need to use a lot of force.
    • Start in the middle and work your way around the perimeter.
  4. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: Schritt 4, Bild 1 von 2 Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: Schritt 4, Bild 2 von 2
    • Using a Phillips #1 screwdriver, remove the two 7mm screws that hold the volume button circuit board to the control panel.
    • Also remove the single 7mm screw from the power button circuit board on the opposite side.
    • There will be a little plastic piece under the eject button that you can just remove and set aside.
  5. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: Schritt 5, Bild 1 von 2 Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: Schritt 5, Bild 2 von 2
    • Desolder the three solders joints connecting the wires to the volume button circuit board.
    • Do the same to the power button circuit board on the other side (the board with only one screw).
    • Pull out the wires using a lot of force.
    • If you are not familiar or comfortable with soldering, use this guide
Abschluss
Ben Toland
101 Reputation
1 Anleitung geschrieben
Cal Poly, Team 17-33, Amido Winter 2015 Mitglied von Cal Poly, Team 17-33, Amido Winter 2015
CPSU-AMIDO-W15S17G33
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 20
Insgesamt: 2,469
