Einleitung
The woofer is the part of the speaker that outputs lower frequency sounds. Replacement of the woofer requires removal of the batteries, the volume and power buttons, and motherboard. Soldering skills are required; take a look at this soldering guide for extra help.
Was du brauchst
Gently push down on the two tabs at the top of the battery door.
While holding them down, slowly pull the door towards you.
Pry off the control panel on top of the speaker using the metal spudger. You may need to use a lot of force.
Using a Phillips #1 screwdriver, remove the two 7mm screws that hold the volume button circuit board to the control panel.
Also remove the single 7mm screw from the power button circuit board on the opposite side.
Desolder the three solders joints connecting the wires to the volume button circuit board.
Do the same to the power button circuit board on the other side (the board with only one screw).
Pull out the wires using a lot of force.
Gently pry open the silver plastic lining of the iPod dock using the plastic spudger.
It is best to start from the top or bottom, then work your way around if it has not popped out yet.
Remove the silver lining.
Pry open the metal mesh by working the plastic spudger around the inside of the mesh.
Once loose, lift up the metal mesh.
Remove the fourteen 30mm screws with Phillips #1 Screwdriver.
Remove the 7mm screw with the Phillips #1 Screwdriver.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
