Zum Hauptinhalt wechseln
Altec Lansing inMotion iM9 Woofer Replacement
Was du brauchst
  1. Altec Lansing inMotion iM9 Woofer Replacement, Battery: Schritt 1, Bild 1 von 1
    • Gently push down on the two tabs at the top of the battery door.
    • While holding them down, slowly pull the door towards you.
  2. Altec Lansing inMotion iM9 Woofer Replacement: Schritt 2, Bild 1 von 1
    • Once the door is open, use your hand to pull out the four batteries.
  3. Altec Lansing inMotion iM9 Woofer Replacement, Volume and Power Buttons: Schritt 3, Bild 1 von 2 Altec Lansing inMotion iM9 Woofer Replacement, Volume and Power Buttons: Schritt 3, Bild 2 von 2
    • Pry off the control panel on top of the speaker using the metal spudger. You may need to use a lot of force.
    • Start in the middle and work your way around the perimeter.
  4. Altec Lansing inMotion iM9 Woofer Replacement: Schritt 4, Bild 1 von 2 Altec Lansing inMotion iM9 Woofer Replacement: Schritt 4, Bild 2 von 2
    • Using a Phillips #1 screwdriver, remove the two 7mm screws that hold the volume button circuit board to the control panel.
    • Also remove the single 7mm screw from the power button circuit board on the opposite side.
    • There will be a little plastic piece under the eject button that you can just remove and set aside.
  5. Altec Lansing inMotion iM9 Woofer Replacement: Schritt 5, Bild 1 von 2 Altec Lansing inMotion iM9 Woofer Replacement: Schritt 5, Bild 2 von 2
    • Desolder the three solders joints connecting the wires to the volume button circuit board.
    • Do the same to the power button circuit board on the other side (the board with only one screw).
    • Pull out the wires using a lot of force.
    • If you are not familiar or comfortable with soldering, use this guide
  6. Altec Lansing inMotion iM9 Woofer Replacement, Case Opening: Schritt 6, Bild 1 von 2 Altec Lansing inMotion iM9 Woofer Replacement, Case Opening: Schritt 6, Bild 2 von 2
    • Gently pry open the silver plastic lining of the iPod dock using the plastic spudger.
    • It is best to start from the top or bottom, then work your way around if it has not popped out yet.
    • Remove the silver lining.
  7. Altec Lansing inMotion iM9 Woofer Replacement: Schritt 7, Bild 1 von 2 Altec Lansing inMotion iM9 Woofer Replacement: Schritt 7, Bild 2 von 2
    • Pry open the metal mesh by working the plastic spudger around the inside of the mesh.
    • Once loose, lift up the metal mesh.
  8. Altec Lansing inMotion iM9 Woofer Replacement: Schritt 8, Bild 1 von 1
    • Remove the fourteen 30mm screws with Phillips #1 Screwdriver.
    • Remove the 7mm screw with the Phillips #1 Screwdriver.
  9. Altec Lansing inMotion iM9 Woofer Replacement: Schritt 9, Bild 1 von 1
    • Carefully separate the front and back case plates at a corner of the speaker.
    • Lots of cables are still connected, so be very gentle when separating case plates.
  10. Altec Lansing inMotion iM9 Woofer Replacement: Schritt 10, Bild 1 von 1
    • Guide the white button cables through the hole on the top of speaker case.
  11. Altec Lansing inMotion iM9 Woofer Replacement: Schritt 11, Bild 1 von 1
    • Use your fingers to peel the glue off of the red and black cables.
  12. Altec Lansing inMotion iM9 Woofer Replacement: Schritt 12, Bild 1 von 1
    • Careful not to touch the green capacitors or you might shock yourself.
  13. Altec Lansing inMotion iM9 Woofer Replacement, Woofer: Schritt 13, Bild 1 von 1
    • Take out the woofer from the front of the speaker with cable attached.
  14. Altec Lansing inMotion iM9 Woofer Replacement: Schritt 14, Bild 1 von 1
    • Desolder the cable from the woofer.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Johnson Zhou
240 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 17-33, Amido Winter 2015 Mitglied von Cal Poly, Team 17-33, Amido Winter 2015
CPSU-AMIDO-W15S17G33
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 19
Insgesamt: 1,080
