Zum Hauptinhalt wechseln
Anker SoundCore 2 Microphone Replacement
Was du brauchst
  1. Anker SoundCore 2 Microphone Replacement, Front Panel: Schritt 1, Bild 1 von 2 Anker SoundCore 2 Microphone Replacement, Front Panel: Schritt 1, Bild 2 von 2
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
  2. Anker SoundCore 2 Microphone Replacement, Microphone: Schritt 2, Bild 1 von 3 Anker SoundCore 2 Microphone Replacement, Microphone: Schritt 2, Bild 2 von 3 Anker SoundCore 2 Microphone Replacement, Microphone: Schritt 2, Bild 3 von 3
    • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Flip up the speaker mount panel from the speaker housing case.
  3. Anker SoundCore 2 Microphone Replacement: Schritt 3, Bild 1 von 3 Anker SoundCore 2 Microphone Replacement: Schritt 3, Bild 2 von 3 Anker SoundCore 2 Microphone Replacement: Schritt 3, Bild 3 von 3
    • Disconnect the microphone wire from the motherboard.
    • Use a spudger to pry the microphone out of the speaker mount panel.
    • The microphone is held in place with glue, so you may need to re-glue the new microphone onto the speaker mount panel.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 33
Insgesamt: 1,046
