Zum Hauptinhalt wechseln
Anker SoundCore 2 Motherboard Replacement
Was du brauchst
  1. Anker SoundCore 2 Motherboard Replacement, Front Panel: Schritt 1, Bild 1 von 2 Anker SoundCore 2 Motherboard Replacement, Front Panel: Schritt 1, Bild 2 von 2
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
  2. Anker SoundCore 2 Motherboard Replacement, Motherboard: Schritt 2, Bild 1 von 3 Anker SoundCore 2 Motherboard Replacement, Motherboard: Schritt 2, Bild 2 von 3 Anker SoundCore 2 Motherboard Replacement, Motherboard: Schritt 2, Bild 3 von 3
    • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Use your hand to remove the speakers.
  3. Anker SoundCore 2 Motherboard Replacement: Schritt 3, Bild 1 von 3 Anker SoundCore 2 Motherboard Replacement: Schritt 3, Bild 2 von 3 Anker SoundCore 2 Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Remove the 10 mm screw that is holding the motherboard in place using a Phillips #0 screwdriver.
    • Flip up the motherboard and disconnect the cord that connects the motherboard and the battery.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Kristen Gismondi
92.267 Reputation
241 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
118 Mitglieder
19.529 Anleitungen geschrieben
3 Kommentare
Where can I buy the C34 and ESD4?
Abel Omeokwe - Antwort
Hello.
Do you know where to fond an Anker motherboard please?
Thanks
ckridene - Antwort
Princelee Balasingham Prince - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 30
Insgesamt: 1,758
