Einleitung
This guide will show you how to replace the motherboard in your Anker Soundcore Space Q45 headphones. You will need to remove the outer casing of the right headphone to access the motherboard.
Was du brauchst
Use the iFixit opening tool to disconnect six clips holding the outer covering in place.
Remove three screws holding the inner plastic covering in place with a Phillips screwdriver.
Remove the inner plastic covering using an iFixit opening tool.
Remove two screws from the motherboard with a Phillips screwdriver.
Remove the motherboard from the headphones.
Eine weitere Person hat diese Anleitung absolviert.
