Zum Hauptinhalt wechseln
Answering Machine Speaker Replacement
Was du brauchst
  1. Answering Machine Speaker Replacement, Base: Schritt 1, Bild 1 von 1
    • Turn the base over. You will see four 11mm Phillips #0 screws, one in each corner.
    • Use a screwdriver to remove all four 11mm Phillips #0 screws.
  2. Answering Machine Speaker Replacement: Schritt 2, Bild 1 von 2 Answering Machine Speaker Replacement: Schritt 2, Bild 2 von 2
    • Locate an easy seam for entry and insert the metal spudger to separate the plastic. Use the spudger in multiple places if necessary.
    • Opening the base may require exerting significant force as it is bound together tightly. This step can be dangerous.
    • The spudger is designed to make this step easier.
  3. Answering Machine Speaker Replacement, Answering Machine Speaker: Schritt 3, Bild 1 von 2 Answering Machine Speaker Replacement, Answering Machine Speaker: Schritt 3, Bild 2 von 2
    • Locate the speaker at the top left of the base as pictured. It is the silver, conical component. Two 7mm Phillips #0 screws hold the speaker in place.
    • Use a screwdriver to remove the two 7mm Phillips #0 screws.
  4. Answering Machine Speaker Replacement: Schritt 4, Bild 1 von 1
    • Finish speaker removal by cutting both the black and red wires.
  5. Answering Machine Speaker Replacement: Schritt 5, Bild 1 von 1
Abschluss
IUPUI, Team 3-3, Harley Fall 2016 Mitglied von IUPUI, Team 3-3, Harley Fall 2016
IUPUI-HARLEY-F16S3G3
4 Mitglieder
17 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 14
Insgesamt: 641
