Zum Hauptinhalt wechseln
Aoson R103 Speakers Replacement
Was du brauchst
  1. Aoson R103 Speakers Replacement, Aoson R103 Opening and Disassembly: Schritt 1, Bild 1 von 3 Aoson R103 Speakers Replacement, Aoson R103 Opening and Disassembly: Schritt 1, Bild 2 von 3 Aoson R103 Speakers Replacement, Aoson R103 Opening and Disassembly: Schritt 1, Bild 3 von 3
    • Turn off the device using the power button.
    • Using fingernails/a pry tool, separate the back panel of the device. This may decent force as they are connected by push tabs.
    • Be careful not to drop the device when separating, this could cause permanent damage.
    • This will expose the motherboard of the device.
  2. Aoson R103 Speakers Replacement: Schritt 2, Bild 1 von 2 Aoson R103 Speakers Replacement: Schritt 2, Bild 2 von 2
    • Use your fingers to unclip the ribbon connecter and then pull the ribbon out of the connector.
    • This ribbon connects the power button and stops the device from turning on; allowing further procedure.
  3. Aoson R103 Speakers Replacement, Speakers: Schritt 3, Bild 1 von 3 Aoson R103 Speakers Replacement, Speakers: Schritt 3, Bild 2 von 3 Aoson R103 Speakers Replacement, Speakers: Schritt 3, Bild 3 von 3
    • The motherboard connections to the speaker are circled, they will be needed later.
    • The two speakers are circled in orange, they are attached to a plastic piece via a screw.
    • The 4.0mm long philips-head 00 screw will be disconnected at the Boxed area where the plastic disconnects.
    • Be careful not to disconnect the back ground wire when taking the plastic off.
  4. Aoson R103 Speakers Replacement: Schritt 4, Bild 1 von 2 Aoson R103 Speakers Replacement: Schritt 4, Bild 2 von 2
    • The box contains the four (4) soldering connections for the two speakers. Unsolder the old speakers and solder the new speakers in.
    • Be sure to match up the appropriately placed speaker to its correct positive or negative node. mixing these up could distort audio or fry the speakers.
    • Note: solder over a piece of paper where you can mark each node with a red or black marker to denote positive and negative nodes for the left or right speaker.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Louis
208 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 17
Insgesamt: 171
