Zum Hauptinhalt wechseln
Apalus Digital Hair Straightening Brush Heating Element Replacement
Was du brauchst
  1. Apalus Digital Hair Straightening Brush Heating Element Replacement, Heating Element: Schritt 1, Bild 1 von 1
    • Remove the seven 5mm Phillips #1 screws on the comb-side of the brush.
  2. Apalus Digital Hair Straightening Brush Heating Element Replacement: Schritt 2, Bild 1 von 1
    • Turn comb over so the bristles are facing down.
    • Remove backside of the comb and place aside.
  3. Apalus Digital Hair Straightening Brush Heating Element Replacement: Schritt 3, Bild 1 von 1
    • Unplug the power cord from the connector inside of the brush.
  4. Apalus Digital Hair Straightening Brush Heating Element Replacement: Schritt 4, Bild 1 von 1
    • Remove the circuit board and heating element from the handle.
    • This will provide easy access to the necessary components.
  5. Apalus Digital Hair Straightening Brush Heating Element Replacement: Schritt 5, Bild 1 von 1
    • Remove the four 6mm Phillips #2 screws holding the heat shield onto the back side of the bristles.
  6. Apalus Digital Hair Straightening Brush Heating Element Replacement: Schritt 6, Bild 1 von 1
    • There are 4 solder points of the heating element located on the LCD side of the circuit board.
    • Desolder these four connections using a soldering iron.
    • Note which wires go to each of the connection points.
    • Soldering Technique Guide
  7. Apalus Digital Hair Straightening Brush Heating Element Replacement: Schritt 7, Bild 1 von 1
    • Solder the new heating element to the same connection points as they were removed from.
Abschluss
Aaron Brysch
231 Reputation
2 Anleitungen geschrieben
IUPUI, Team S1-G3, Harley Fall 2017 Mitglied von IUPUI, Team S1-G3, Harley Fall 2017
IUPUI-HARLEY-F17S1G3
3 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 25
Insgesamt: 2,217
