Einleitung
Instructions to remove and replace a damaged or non-functioning internal speaker.
Was du brauchst
Begin by inserting the plastic opening tool into the seam between the back and front of the case and carefully pry the back from the front.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Moving along the seam continue to pry the case apart.
The back panel should now be disconnected from the device. This provides access to the components of the device for repairing and replacing parts of the tablet.
Locate the soldering points where the wires have been connected to the circuit board.
Desolder the red wire the positive (+)
Desolder the black wire to the negative (-).
