Was du brauchst
Follow the Apple Lisa Disassembly Guide to remove the Lisa's real panel.
Locate Lisa's expansion slots.
Locate expansion slot 2.
Pull the metal rod out from slot 2 and rotate 90º clockwise.
Slide the Lisa DAC into expansion slot 2.
Rotate the metal rod, as described before, 90º counter-clockwise and push in to secure the Lisa DAC.
The Lisa DAC software can be found here.
Lisa DAC requires MacWorks Plus II.
Fast fertig!
Abschluss
