Einführungsvideo
Apple APL1109/339S01081E M2 octa-core applications processor & graphics processing unit
Micron MT62F1G64D8WT-031 XT:B 8 GB LPDDR5 SDRAM memory
Apple APL1W08/339S01186 R1 sensor coprocessor
Kioxia K5A4RC2097 256 GB NAND flash
Apple APL109C/343S00627 power management
Apple APL109D/343S00628 power management
Apple APL1004/343S00629 power management
Apple 338S00521-B0 power management
Texas Instruments LMK1C1104 clock buffer
Analog Devices LT8652S 8.5 A / 18 V dual channel synchronous step-down converter
Texas Instruments TPS62125 300 mA buck converter
Texas Instruments TPS61045 adjustable boost converter
onsemi FPF2895C current limit switch
Texas Instruments TPS70936 150 mA / 3.6 V LDO regulator
Analog Devices TMC5072 dual 2-phase stepper motor driver
Lattice Semiconductor ICE5LP4K iCE40 Ultra FPGA
Likely Cirrus Logic CS46L11 audio codec
Diodes Incorporated PI2DBS16212A 2:1 multiplexer/demultiplexer
Texas Instruments TMUX1575 quad SPDT analog switch
Texas Instruments TS5A23159 dual SPDT analog switch
Texas Instruments TPS62135 4 A step-down converter
STMicroelectronics STM32L4A6VG Arm Cortex-M4 microcontroller
GigaDevice GD25Q80E 1 MB serial NOR flash memory
Texas Instruments CD3217B13 USB type-C controller
Texas Instruments TPD4S311A USB type-C port protector
Texas Instruments TPS62180 6 A synchronous buck converter
Texas Instruments TPS62160 1 A step-down converter
Texas Instruments SN02776B0A audio amplifier
7 Kommentare
No ID of the sensor chips?
What do you think the Diodes Incorporated PI2DBS16212A 2:1 multiplexer/demultiplexer is for? What do you think the long module is at the bottom left of the main board?
What IC's control all the LEDs, cameras, etc? Are these in a module somewhere?
Where’s four imu chip
