Zum Hauptinhalt wechseln
Archos 101 G9 Display Assembly Replacement
Was du brauchst
  1. Archos 101 G9 Display Assembly Replacement, Display Assembly: Schritt 1, Bild 1 von 1
    • Place an iFixit opening tool in the crease where the display assembly and back of the device meet.
    • Slide the tool firmly through the crease on one side of the device, twisting as you go to create separation.
    • When you reach the corner, carefully pry the two halves of the device apart.
    • There are small clips along the edges that need to stay intact in order to properly reassemble the device. Be very gentle when prying so as not to break the clips.
    • Repeat for the remaining three sides and corners.
  2. Archos 101 G9 Display Assembly Replacement: Schritt 2, Bild 1 von 2 Archos 101 G9 Display Assembly Replacement: Schritt 2, Bild 2 von 2
    • Separate the halves of the device.
    • Ensure that you separate from the top and you keep the bottoms of both pieces near each other so as not to damage the ribbon cables that connect the halves.
  3. Archos 101 G9 Display Assembly Replacement: Schritt 3, Bild 1 von 2 Archos 101 G9 Display Assembly Replacement: Schritt 3, Bild 2 von 2
    • Gently remove both ribbon cables from their sockets on the motherboard.
  4. Archos 101 G9 Display Assembly Replacement: Schritt 4, Bild 1 von 1
    • Remove the white and black coaxial cables with gold tips from the motherboard.
  5. Archos 101 G9 Display Assembly Replacement: Schritt 5, Bild 1 von 1
    • Remove the display assembly from the back panel.
Abschluss
Clay Meunier
557 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 4-1, Gulbrandsen Fall 2021 Mitglied von UMass Dartmouth, Team 4-1, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G1
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 241
