Zum Hauptinhalt wechseln
Arlo Ultra 2 Spotlight Replacement
Was du brauchst
  1. Arlo Ultra 2 Spotlight Replacement, Battery: Schritt 1, Bild 1 von 2 Arlo Ultra 2 Spotlight Replacement, Battery: Schritt 1, Bild 2 von 2
    • Press the button on the bottom of the camera to release the case.
    • Pull the white case off of camera.
  2. Arlo Ultra 2 Spotlight Replacement: Schritt 2, Bild 1 von 1
    • Pull the white cube shaped battery from the back to remove it from camera.
  3. Arlo Ultra 2 Spotlight Replacement, Spotlight: Schritt 3, Bild 1 von 2 Arlo Ultra 2 Spotlight Replacement, Spotlight: Schritt 3, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the four 20.0 mm screws from the battery cavity.
  4. Arlo Ultra 2 Spotlight Replacement: Schritt 4, Bild 1 von 2 Arlo Ultra 2 Spotlight Replacement: Schritt 4, Bild 2 von 2
    • Use a spudger to loosen and remove the camera faceplate.
  5. Arlo Ultra 2 Spotlight Replacement: Schritt 5, Bild 1 von 2 Arlo Ultra 2 Spotlight Replacement: Schritt 5, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the two 4.00 mm black screws located across from each other above the camera lens.
  6. Arlo Ultra 2 Spotlight Replacement: Schritt 6, Bild 1 von 2 Arlo Ultra 2 Spotlight Replacement: Schritt 6, Bild 2 von 2
    • Use a spudger or your fingernail to flip up the small locking flap on the ZIF connector. Then, you can safely pull the cable out.
    • The cable is very short and you will see it when removing the circuit board.
  7. Arlo Ultra 2 Spotlight Replacement: Schritt 7, Bild 1 von 2 Arlo Ultra 2 Spotlight Replacement: Schritt 7, Bild 2 von 2
    • Use a spudger to gently pry the green circuit board away from the case.
    • Remove the green circuit board. This is your spotlight.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Great tutorial, very helpful. A suggestion however would be to also offer for sale or add links to where the replacement components can be purchased. In this instance I could not find a replacement spotlight and had to buy a donor camera. Thanks
Gareth - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 118
