Einleitung
This guide will show you how to replace a I/O board in an Asus A53S.
An I/O board allows you to connect a wide range of devices to your laptop.
Before using this guide, make sure to review the troubleshooting page. Most USB-related issues can be solved without removing the I/O board.
Make sure to power off your laptop completely, disconnect from any external power source, and remove the battery before beginning the process.
Was du brauchst
Flip the laptop so the underside is facing up.
Using a Phillips #01 screwdriver, unscrew the two 6 mm screws.
Remove the back plate.
Place the spudger under the white wire and pull it up gently, disconnecting it from the wifi card.
Use the same method on the black wire.
Using a Phillips #01 screwdriver, unscrew the fifteen 6 mm screws at the indicated places.
Flip over the laptop and open it.
Using the spudger, insert the flat end into the notches at the top of the keyboard and slowly slide and "pop" the keyboard up and out of the device.
Using the flat end of the spudger, lift the black ZIF connector lock bar and disconnect the keyboard from the computer.
Remove the keyboard.
Using the spudger, place the flat end under the ZIF connector lock bar holding the power switch. Push the spudger up and to the left, disconnecting the power switch.
Use the same technique on the touchpad to disconnect it.
Using a Phillips #01 screwdriver, unscrew the seven 6 mm screws at the indicated places.
Flip the laptop back over so that the bottom is facing up.
Use a Phillips #01 screwdriver to unscrew the three 6 mm screws at the indicated places.
Turn the laptop back over so that you can open it.
Gently separate the cover from the laptop by putting an iFixit Opening Tool between the cover and the lower part of the laptop and levering them apart.
Using the flat end of a spudger, flip up the ZIF connector lock bar, disconnecting the USB board from the mother board.
Repeat this technique on the other side of the USB connector.
Using a Phillips #01 screwdriver, unscrew the 5 mm screw at the indicated place.
Gently remove the USB board.
3 weitere Personen haben diese Anleitung absolviert.
