Zum Hauptinhalt wechseln
Asus CM1745 Heatsink Replacement
Was du brauchst
  1. Asus CM1745 Heatsink Replacement, Heatsink: Schritt 1, Bild 1 von 2 Asus CM1745 Heatsink Replacement, Heatsink: Schritt 1, Bild 2 von 2
    • Remove the sidepanel by unscrewing the two screws fastening the panel on the rear. Once unscrewed, slide the panel towards the rear until it releases then lift away.
  2. Asus CM1745 Heatsink Replacement: Schritt 2, Bild 1 von 2 Asus CM1745 Heatsink Replacement: Schritt 2, Bild 2 von 2
    • Unplug the CPU fan connector from the motherboard.
    • Then open the latch under the CPU fan and unhook the metal fasteners.
    • Lift the CPU heatsink and cable off of the CPU carefully.
  3. Asus CM1745 Heatsink Replacement: Schritt 3, Bild 1 von 3 Asus CM1745 Heatsink Replacement: Schritt 3, Bild 2 von 3 Asus CM1745 Heatsink Replacement: Schritt 3, Bild 3 von 3
    • Clean both the CPU top and the heatsink bottom by slightly moistening a paper towel with rubbing alcohol and rubbing lightly.
    • Grab your thermal paste and put a pea-sized amount in the middle of the CPU top.
    • Gently replace the heatsink on top of the CPU and re-lock the heatsink fasteners.
    • Replug the CPU Fan connector to the motherboard header.
    • Check out the How to Apply Thermal Paste guide for more details and best practices.
Abschluss
Replug the computer and turn it on. If the fan spins, reattach the sidepanels and the replacement is complete.
TC Fowlar
794 Reputation
5 Anleitungen geschrieben
University of Memphis, Team S4-G2, Kim Fall 2019 Mitglied von University of Memphis, Team S4-G2, Kim Fall 2019
UM-KIM-F19S4G2
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 16
Letzte 30 Tage: 73
Insgesamt: 533
