Zum Hauptinhalt wechseln
Asus Chromebook C101P Heat Sink Replacement
Was du brauchst
  1. Asus Chromebook C101P Heat Sink Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Flip the Chromebook so that the bottom is facing up.
    • Remove the nine T5 Torx screws.
  2. Asus Chromebook C101P Heat Sink Replacement: Schritt 2, Bild 1 von 1
    • Remove the four rubber grips on the bottom side of the Chromebook using an opening tool.
  3. Asus Chromebook C101P Heat Sink Replacement: Schritt 3, Bild 1 von 1
    • Remove the four black screws where the rubber grips were.
  4. Asus Chromebook C101P Heat Sink Replacement: Schritt 4, Bild 1 von 2 Asus Chromebook C101P Heat Sink Replacement: Schritt 4, Bild 2 von 2
    • Reorient the Chromebook so the right side is facing upwards.
    • Wedge an opening tool or spudger between the keyboard (upper case) and the lower case of the bottom portion of the Chromebook.
  5. Asus Chromebook C101P Heat Sink Replacement: Schritt 5, Bild 1 von 3 Asus Chromebook C101P Heat Sink Replacement: Schritt 5, Bild 2 von 3 Asus Chromebook C101P Heat Sink Replacement: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the large ribbon cable.
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the small ribbon cable.
    • Separate the keyboard from the rest of the laptop.
  6. Asus Chromebook C101P Heat Sink Replacement, Heat Sink: Schritt 6, Bild 1 von 2 Asus Chromebook C101P Heat Sink Replacement, Heat Sink: Schritt 6, Bild 2 von 2
    • Detach the the screen cables from the motherboard using a pair of tweezers.
    • Peel off the tape or seal to easily remove the screen cables.
  7. Asus Chromebook C101P Heat Sink Replacement: Schritt 7, Bild 1 von 1
    • Flip up the black lever on the base of the small white ribbon cable. Remove the cable and set it aside.
  8. Asus Chromebook C101P Heat Sink Replacement: Schritt 8, Bild 1 von 1
    • Remove the nine Phillips #0 screws.
    • The 3 circles on the hand indicate that there are 3 more screws not visible in the photo.
    • Remove the battery cable if possible. Otherwise, gently flip the motherboard upside down to reveal the heat sink.
    • The motherboard may be hot. Be sure that you have left the Chromebook turned off for a few minutes.
  9. Asus Chromebook C101P Heat Sink Replacement: Schritt 9, Bild 1 von 2 Asus Chromebook C101P Heat Sink Replacement: Schritt 9, Bild 2 von 2
    • Remove the four Phillips #0 screws from the heat sink.
    • Detach the heat sink from the motherboard.
    • Detaching may provide a bit of resistance because of thermal paste.
    • When you are ready to apply the new heat sink, be sure to apply a small dab of thermal paste onto the CPU.
Abschluss
Dan Sysopha
369 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S1-G2, O'Connell Fall 2019 Mitglied von UMass Dartmouth, Team S1-G2, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G2
2 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 33
Insgesamt: 1,153
