Zum Hauptinhalt wechseln
Asus Chromebook C300SA-DS02 Display Assembly Replacement
Was du brauchst
  1. Asus Chromebook C300SA-DS02 Display Assembly Replacement, Keyboard: Schritt 1, Bild 1 von 2 Asus Chromebook C300SA-DS02 Display Assembly Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Asus Chromebook C300SA-DS02 Display Assembly Replacement: Schritt 2, Bild 1 von 3 Asus Chromebook C300SA-DS02 Display Assembly Replacement: Schritt 2, Bild 2 von 3 Asus Chromebook C300SA-DS02 Display Assembly Replacement: Schritt 2, Bild 3 von 3
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Asus Chromebook C300SA-DS02 Display Assembly Replacement: Schritt 3, Bild 1 von 3 Asus Chromebook C300SA-DS02 Display Assembly Replacement: Schritt 3, Bild 2 von 3 Asus Chromebook C300SA-DS02 Display Assembly Replacement: Schritt 3, Bild 3 von 3
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Asus Chromebook C300SA-DS02 Display Assembly Replacement: Schritt 4, Bild 1 von 1
    • Remove the keyboard from the laptop.
  5. Asus Chromebook C300SA-DS02 Display Assembly Replacement, Battery: Schritt 5, Bild 1 von 2 Asus Chromebook C300SA-DS02 Display Assembly Replacement, Battery: Schritt 5, Bild 2 von 2
    • Remove the six 5.6mm Phillips #0 screws around the battery.
  6. Asus Chromebook C300SA-DS02 Display Assembly Replacement: Schritt 6, Bild 1 von 2 Asus Chromebook C300SA-DS02 Display Assembly Replacement: Schritt 6, Bild 2 von 2
    • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
  7. Asus Chromebook C300SA-DS02 Display Assembly Replacement: Schritt 7, Bild 1 von 1
    • Lift the battery out of the laptop.
  8. Asus Chromebook C300SA-DS02 Display Assembly Replacement, Display Assembly: Schritt 8, Bild 1 von 2 Asus Chromebook C300SA-DS02 Display Assembly Replacement, Display Assembly: Schritt 8, Bild 2 von 2
    • Unplug the black and white cable from the motherboard.
    • These two wires connect to the antenna within the display assembly. The white cable is longer and connects to the bottom import.
  9. Asus Chromebook C300SA-DS02 Display Assembly Replacement: Schritt 9, Bild 1 von 1
    • Peel back the tape covering the display cable.
    • Ease the cable towards the screen and out from the connector.
  10. Asus Chromebook C300SA-DS02 Display Assembly Replacement: Schritt 10, Bild 1 von 1
    • Use a Phillips #0 driver to remove the six 5mm screws on the top right and left display hinges.
  11. Asus Chromebook C300SA-DS02 Display Assembly Replacement: Schritt 11, Bild 1 von 1
    • Gently lift the display assembly up and away from the laptop.
Abschluss
Celina Monteiro
224 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S1-G7, Simcock Fall 2017 Mitglied von UMass Dartmouth, Team S1-G7, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G7
3 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 188
