Zum Hauptinhalt wechseln
Asus Chromebook Flip C302CA Wi-Fi Card Replacement
Was du brauchst
  1. Asus Chromebook Flip C302CA Wi-Fi Card Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Turn the laptop over so the bottom is facing you.
  2. Asus Chromebook Flip C302CA Wi-Fi Card Replacement: Schritt 2, Bild 1 von 3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement: Schritt 2, Bild 2 von 3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement: Schritt 2, Bild 3 von 3
    • Remove two rubber caps on the top.
    • Remove the two 1 mm screws using the Phillips #00 screwdriver.
  3. Asus Chromebook Flip C302CA Wi-Fi Card Replacement: Schritt 3, Bild 1 von 3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement: Schritt 3, Bild 2 von 3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement: Schritt 3, Bild 3 von 3
    • Remove the ten 2 mm screws from the back panel using a T5 Torx screwdriver.
    • Carefully remove the back panel using an opening pick.
  4. Asus Chromebook Flip C302CA Wi-Fi Card Replacement: Schritt 4, Bild 1 von 2 Asus Chromebook Flip C302CA Wi-Fi Card Replacement: Schritt 4, Bild 2 von 2
    • Remove the back panel from the laptop.
  5. Asus Chromebook Flip C302CA Wi-Fi Card Replacement, Battery: Schritt 5, Bild 1 von 3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement, Battery: Schritt 5, Bild 2 von 3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement, Battery: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the sticker holding the cable using a pair of tweezers.
    • Detach the cable from the motherboard by lifting it up with a spudger.
    • Always use a plastic or nylon ESD-safe tool. Metal spudger and other sharp tools can puncture a battery, potentially causing a fire.
  6. Asus Chromebook Flip C302CA Wi-Fi Card Replacement: Schritt 6, Bild 1 von 2 Asus Chromebook Flip C302CA Wi-Fi Card Replacement: Schritt 6, Bild 2 von 2
    • Remove the two 2 mm screws holding the battery using a Phillips #00 screwdriver.
  7. Asus Chromebook Flip C302CA Wi-Fi Card Replacement: Schritt 7, Bild 1 von 1
    • Carefully lift up the battery from the front side to remove it from the laptop.
  8. Asus Chromebook Flip C302CA Wi-Fi Card Replacement, Wi-Fi Card: Schritt 8, Bild 1 von 3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement, Wi-Fi Card: Schritt 8, Bild 2 von 3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement, Wi-Fi Card: Schritt 8, Bild 3 von 3
    • Carefully remove the black and white cables connected to the Wi-Fi card.
    • Remove the single 2 mm screw while holding the Wi-Fi card using the Phillips #00 screwdriver.
    • Remove the Wi-Fi card from the laptop.
Abschluss
Gateway, Team 1-2, Saknee Spring 2022 Mitglied von Gateway, Team 1-2, Saknee Spring 2022
GCC-SAKNEE-S22S1G2
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 372
