Zum Hauptinhalt wechseln
Asus F555LA-AB31 CD Drive Replacement
Was du brauchst
  1. Asus F555LA-AB31 CD Drive Replacement, CD Drive: Schritt 1, Bild 1 von 1
    • Turn off and unplug the device before starting repairing.
    • Use the Phillips #0 screwdriver head to remove the ten 18mm Phillips #0 screws on the laptop's bottom.
  2. Asus F555LA-AB31 CD Drive Replacement: Schritt 2, Bild 1 von 2 Asus F555LA-AB31 CD Drive Replacement: Schritt 2, Bild 2 von 2
    • Flip the laptop over and flip the screen up.
    • Pry upward on the edges of the faceplate in order to separate the keyboard and trackpad from the rest of the device.
    • Be cautious of the cables connecting the keyboard and trackpad to the motherboard.
  3. Asus F555LA-AB31 CD Drive Replacement: Schritt 3, Bild 1 von 1
    • Disconnect the keyboard flex cable from its motherboard ZIF socket.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap. Carefully slide the unlocked cable out of the socket.
  4. Asus F555LA-AB31 CD Drive Replacement: Schritt 4, Bild 1 von 2 Asus F555LA-AB31 CD Drive Replacement: Schritt 4, Bild 2 von 2
    • Use the Phillips #0 screwdriver to unscrew the one Phillips #0 screw that connects the CD drive to the motherboard.
    • Slowly slide out the CD drive, keeping it level, to remove it.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 384
