Einleitung
This guide has four uncomplicated and easy-to-follow steps to replace the CD drive of your Asus F555LA-AB31 laptop.
There are just two things that could be wrong with your CD drive. The first one is that you might have a faulty drive, which is highly unlikely. The second one, which is the most common problem, is faulty drivers; you may find that discs are not being read correctly.
Before completing this guide, unplug and turn off your laptop.
Was du brauchst
Use the Phillips #0 screwdriver head to remove the ten 18mm Phillips #0 screws on the laptop's bottom.
Flip the laptop over and flip the screen up.
Pry upward on the edges of the faceplate in order to separate the keyboard and trackpad from the rest of the device.
Use the Phillips #0 screwdriver to unscrew the one Phillips #0 screw that connects the CD drive to the motherboard.
Slowly slide out the CD drive, keeping it level, to remove it.
