Zum Hauptinhalt wechseln
Asus G75VW-BHI7N07 USB Port Replacement
Was du brauchst
  1. Asus G75VW-BHI7N07 USB Port Replacement, USB Port: Schritt 1, Bild 1 von 3 Asus G75VW-BHI7N07 USB Port Replacement, USB Port: Schritt 1, Bild 2 von 3 Asus G75VW-BHI7N07 USB Port Replacement, USB Port: Schritt 1, Bild 3 von 3
    • Remove the screws around the back cover using a Phillips #1 screwdriver.
    • Take the back cover off using the opening tool.
  2. Asus G75VW-BHI7N07 USB Port Replacement: Schritt 2, Bild 1 von 3 Asus G75VW-BHI7N07 USB Port Replacement: Schritt 2, Bild 2 von 3 Asus G75VW-BHI7N07 USB Port Replacement: Schritt 2, Bild 3 von 3
    • Once you get rid of the back cover, spot all the screws marked ‘A’. There should be 10 in total.
    • Remove the battery using the slide release button.
    • This should expose 2 more ‘A’ marked screws.
    • Remove those using the same screwdriver.
  3. Asus G75VW-BHI7N07 USB Port Replacement: Schritt 3, Bild 1 von 2 Asus G75VW-BHI7N07 USB Port Replacement: Schritt 3, Bild 2 von 2
    • Using the opening tool, remove the disc drive cover.
    • Spot the 6 ‘B’ marked screws and remove them using the Phillips #1 screwdriver.
  4. Asus G75VW-BHI7N07 USB Port Replacement: Schritt 4, Bild 1 von 2 Asus G75VW-BHI7N07 USB Port Replacement: Schritt 4, Bild 2 von 2
    • Using the opening tool, pry open the keypad platform.
    • You will need to use your hands to get to the laptop’s internal systems by lifting the keypad platform.
  5. Asus G75VW-BHI7N07 USB Port Replacement: Schritt 5, Bild 1 von 3 Asus G75VW-BHI7N07 USB Port Replacement: Schritt 5, Bild 2 von 3 Asus G75VW-BHI7N07 USB Port Replacement: Schritt 5, Bild 3 von 3
    • Now that the fans are exposed, use the opening tool to unhook them at the 4 connecting points.
    • Detach the blue-colored electrical component using the opening tool.
    • Detach the white and black colored electrical component using the opening tool.
  6. Asus G75VW-BHI7N07 USB Port Replacement: Schritt 6, Bild 1 von 1
    • Using the Phillips #0 Screwdriver, remove the 5 screws around the edges of the motherboard.
    • Remove the 2 screws around the fan using the Phillips #0 Screwdriver which should be near the motherboard.
  7. Asus G75VW-BHI7N07 USB Port Replacement: Schritt 7, Bild 1 von 1
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Joy
437 Reputation
4 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 17
Insgesamt: 668
