Zum Hauptinhalt wechseln
Asus K53S -X156V Thermal Paste Replacement
Was du brauchst
  1. Asus K53S -X156V Thermal Paste Replacement, removing battery: Schritt 1, Bild 1 von 3 Asus K53S -X156V Thermal Paste Replacement, removing battery: Schritt 1, Bild 2 von 3 Asus K53S -X156V Thermal Paste Replacement, removing battery: Schritt 1, Bild 3 von 3
    • remove battery by sliding the two release buttons to the right position.
    • slide the battery away from the laptop
  2. Asus K53S -X156V Thermal Paste Replacement, removing plastic plate RAM/HDD: Schritt 2, Bild 1 von 2 Asus K53S -X156V Thermal Paste Replacement, removing plastic plate RAM/HDD: Schritt 2, Bild 2 von 2
    • remove the 2 screws holding the plastic plate , underneath is the RAM/ WiFi and HDD
    • the 2 screws are marked in red. afterwarts slide it away from the laptop
    • keep track of all the screws and parts. make a map or a plan.
  3. Asus K53S -X156V Thermal Paste Replacement, removing RAM: Schritt 3, Bild 1 von 3 Asus K53S -X156V Thermal Paste Replacement, removing RAM: Schritt 3, Bild 2 von 3 Asus K53S -X156V Thermal Paste Replacement, removing RAM: Schritt 3, Bild 3 von 3
    • click the ram module out of there sockets.
    • push the metal clips away from the module.
  4. Asus K53S -X156V Thermal Paste Replacement, Remove wifi module: Schritt 4, Bild 1 von 2 Asus K53S -X156V Thermal Paste Replacement, Remove wifi module: Schritt 4, Bild 2 von 2
    • remove the black and white wire.
    • remove the screw.
  5. Asus K53S -X156V Thermal Paste Replacement, removing hard disk: Schritt 5, Bild 1 von 3 Asus K53S -X156V Thermal Paste Replacement, removing hard disk: Schritt 5, Bild 2 von 3 Asus K53S -X156V Thermal Paste Replacement, removing hard disk: Schritt 5, Bild 3 von 3
    • remove the 4 screws holding the metal frame , holding the hdd to it's place.
    • slide the frame and hard disk away from the case.
  6. Asus K53S -X156V Thermal Paste Replacement, removing keyboard: Schritt 6, Bild 1 von 2 Asus K53S -X156V Thermal Paste Replacement, removing keyboard: Schritt 6, Bild 2 von 2
    • click the keyboard loose . There are 5 clips to remove
  7. Asus K53S -X156V Thermal Paste Replacement, keyboard second part: Schritt 7, Bild 1 von 3 Asus K53S -X156V Thermal Paste Replacement, keyboard second part: Schritt 7, Bild 2 von 3 Asus K53S -X156V Thermal Paste Replacement, keyboard second part: Schritt 7, Bild 3 von 3
    • be carefull with the flat cable from the keyboard.
    • use a spudger to click the connector lid loose.
    • i used the tip of a screwdriver.. but i know what i am doing.. if you are use to work on laptops you can use a screwdriver, if not use a plastic spudger.
  8. Asus K53S -X156V Thermal Paste Replacement, remove DVD bay: Schritt 8, Bild 1 von 3 Asus K53S -X156V Thermal Paste Replacement, remove DVD bay: Schritt 8, Bild 2 von 3 Asus K53S -X156V Thermal Paste Replacement, remove DVD bay: Schritt 8, Bild 3 von 3
    • remove the screw hidden under the keyboard.
    • slide the dvd bay out.
  9. Asus K53S -X156V Thermal Paste Replacement, removing flat cables: Schritt 9, Bild 1 von 3 Asus K53S -X156V Thermal Paste Replacement, removing flat cables: Schritt 9, Bild 2 von 3 Asus K53S -X156V Thermal Paste Replacement, removing flat cables: Schritt 9, Bild 3 von 3
    • remove the flat thin cables from there sockets.
    • use a spudger , click the lid upwards and slide the flat cable out.
  10. Asus K53S -X156V Thermal Paste Replacement: Schritt 10, Bild 1 von 3 Asus K53S -X156V Thermal Paste Replacement: Schritt 10, Bild 2 von 3 Asus K53S -X156V Thermal Paste Replacement: Schritt 10, Bild 3 von 3
    • remove the 6 screws ( m2x6) holding the metal plate to the case.
  11. Asus K53S -X156V Thermal Paste Replacement, remove screws on the bottom plate: Schritt 11, Bild 1 von 3 Asus K53S -X156V Thermal Paste Replacement, remove screws on the bottom plate: Schritt 11, Bild 2 von 3 Asus K53S -X156V Thermal Paste Replacement, remove screws on the bottom plate: Schritt 11, Bild 3 von 3
    • remove screws as shown in pictures.
  12. Asus K53S -X156V Thermal Paste Replacement, remove screws bottom plate: Schritt 12, Bild 1 von 3 Asus K53S -X156V Thermal Paste Replacement, remove screws bottom plate: Schritt 12, Bild 2 von 3 Asus K53S -X156V Thermal Paste Replacement, remove screws bottom plate: Schritt 12, Bild 3 von 3
  13. Asus K53S -X156V Thermal Paste Replacement, removing case: Schritt 13, Bild 1 von 3 Asus K53S -X156V Thermal Paste Replacement, removing case: Schritt 13, Bild 2 von 3 Asus K53S -X156V Thermal Paste Replacement, removing case: Schritt 13, Bild 3 von 3
    • slide an isesamo opening tool between the two plates. you will here clicks
  14. Asus K53S -X156V Thermal Paste Replacement, reveal MAIN PCB: Schritt 14, Bild 1 von 3 Asus K53S -X156V Thermal Paste Replacement, reveal MAIN PCB: Schritt 14, Bild 2 von 3 Asus K53S -X156V Thermal Paste Replacement, reveal MAIN PCB: Schritt 14, Bild 3 von 3
    • remove upper plate , revealing the main PCB.
  15. Asus K53S -X156V Thermal Paste Replacement, removing cable to usb module: Schritt 15, Bild 1 von 3 Asus K53S -X156V Thermal Paste Replacement, removing cable to usb module: Schritt 15, Bild 2 von 3 Asus K53S -X156V Thermal Paste Replacement, removing cable to usb module: Schritt 15, Bild 3 von 3
    • remove the flat cable of the USB module , use a spudger to lift up the lid of the connector.
    • gently slide out the flat cable
    • when removing the cable, be carefull they used a lot of adhessive to paste the cable to the plastic case.
  16. Asus K53S -X156V Thermal Paste Replacement, removing LCD cable: Schritt 16, Bild 1 von 3 Asus K53S -X156V Thermal Paste Replacement, removing LCD cable: Schritt 16, Bild 2 von 3 Asus K53S -X156V Thermal Paste Replacement, removing LCD cable: Schritt 16, Bild 3 von 3
    • use the tip of a spudger or a tiny flathead screwdriver to push out the LCD cable from connector.
    • be very very very carefull , if you tear tis cable or damage it , you will have to buy a new one.
    • first lift the cable metal connector upwards ( push it out) , very gently, then the other side untill you can remove the cable.
  17. Asus K53S -X156V Thermal Paste Replacement, remove audio cable: Schritt 17, Bild 1 von 2 Asus K53S -X156V Thermal Paste Replacement, remove audio cable: Schritt 17, Bild 2 von 2
    • use IC extractor pliers to remove the cable away from is socket.
  18. Asus K53S -X156V Thermal Paste Replacement, remove screws main board: Schritt 18, Bild 1 von 3 Asus K53S -X156V Thermal Paste Replacement, remove screws main board: Schritt 18, Bild 2 von 3 Asus K53S -X156V Thermal Paste Replacement, remove screws main board: Schritt 18, Bild 3 von 3
    • remove the 4 screws holding the main pcb ..
  19. Asus K53S -X156V Thermal Paste Replacement, removing last screw.: Schritt 19, Bild 1 von 1
    • remove screw holding the fan tot the laptop.
  20. Asus K53S -X156V Thermal Paste Replacement, removing main board: Schritt 20, Bild 1 von 3 Asus K53S -X156V Thermal Paste Replacement, removing main board: Schritt 20, Bild 2 von 3 Asus K53S -X156V Thermal Paste Replacement, removing main board: Schritt 20, Bild 3 von 3
    • lift the main board or motherboard up on the right side and slide it out.
  21. Asus K53S -X156V Thermal Paste Replacement, FAN: Schritt 21, Bild 1 von 2 Asus K53S -X156V Thermal Paste Replacement, FAN: Schritt 21, Bild 2 von 2
    • release the fan from the main board by removing the connector with an IC extractor pliers.
  22. Asus K53S -X156V Thermal Paste Replacement: Schritt 22, Bild 1 von 3 Asus K53S -X156V Thermal Paste Replacement: Schritt 22, Bild 2 von 3 Asus K53S -X156V Thermal Paste Replacement: Schritt 22, Bild 3 von 3
    • loosen up the screws from the cooling pads on the CPU and GPU.
    • You will have to tear the warranty sticker. it is a sticker in 3 parts.
  23. Asus K53S -X156V Thermal Paste Replacement, removing fan and cooling pads: Schritt 23, Bild 1 von 3 Asus K53S -X156V Thermal Paste Replacement, removing fan and cooling pads: Schritt 23, Bild 2 von 3 Asus K53S -X156V Thermal Paste Replacement, removing fan and cooling pads: Schritt 23, Bild 3 von 3
    • remove the fan and cooling pads.
    • you will see the old thermal paste.
  24. Asus K53S -X156V Thermal Paste Replacement, removing thermal paste from pads.: Schritt 24, Bild 1 von 2 Asus K53S -X156V Thermal Paste Replacement, removing thermal paste from pads.: Schritt 24, Bild 2 von 2
    • clean the cooling pads with an very sharp knife. or spudger..
    • wear gloves, cause the thermal paste is very toxic.
    • also this is a good time to blow out the fan with compressed air.
  25. Asus K53S -X156V Thermal Paste Replacement, removing CPU and cleaning: Schritt 25, Bild 1 von 3 Asus K53S -X156V Thermal Paste Replacement, removing CPU and cleaning: Schritt 25, Bild 2 von 3 Asus K53S -X156V Thermal Paste Replacement, removing CPU and cleaning: Schritt 25, Bild 3 von 3
    • remove the old thermal paste from the processors , be very carefull. and use some artic silver liquid to clean them. and easely remove the thermal paste.
    • you can remove the CPU by using a flathead screwdriver , the socket will move and you can pull the CPU out , maybe a good time to upgrade the CPU.
  26. Asus K53S -X156V Thermal Paste Replacement: Schritt 26, Bild 1 von 1
    • unfortunately i don't have a picture when i added some new thermal paste. But if you do: one drop on each processor is enough.
    • Check out the thermal paste guide for more information on how to apply thermal paste.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Kevin D
7.294 Reputation
21 Anleitungen geschrieben
4 Kommentare
You dont have to disassembly whole computer, just remove back cover, 4 screws from cpu, 2 screws from gpu and 2 screws from fan..
Aleksi Kinnunen - Antwort
Hi Aleksi,
Yes we know, but we took the hole laptop apart to show how to replace, renew other parts as well.
Kevin D - Antwort
Ciao, io ho fatto tutto perfettamente in modo identico alla spiegazione (anche perché non è complicato). può essere la cpu?
Irene Montanari - Antwort
Which themal paste good . Please give amazon purchase link
Vinayak Patil - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 51
Insgesamt: 5,210
