Zum Hauptinhalt wechseln
Asus K55a-si50301p RAM Replacement
Was du brauchst
  1. Asus K55a-si50301p RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Press and slide the two battery retention clips on either side of the battery towards the unlock position.
  2. Asus K55a-si50301p RAM Replacement: Schritt 2, Bild 1 von 1
    • Pull the right side retention clip so that the red indicator is showing.
    • The small graphic below the retention clip denotes locked and unlocked positions. The clip will stay put once moved into position.
  3. Asus K55a-si50301p RAM Replacement: Schritt 3, Bild 1 von 1
    • Pull the retention clip on the left hand side of the laptop away from the battery.
    • Gently pull the battery out with your free hand.
  4. Asus K55a-si50301p RAM Replacement, Lower Back Panel: Schritt 4, Bild 1 von 1
    • Remove the two 8.5mm screws using a PH0 screwdriver.
  5. Asus K55a-si50301p RAM Replacement: Schritt 5, Bild 1 von 1
    • Using the iFixit opening tool, gently pry the plastic cover away from its original position.
  6. Asus K55a-si50301p RAM Replacement: Schritt 6, Bild 1 von 1
    • Gently pull up and then towards you until the plastic cover is free.
  7. Asus K55a-si50301p RAM Replacement, RAM: Schritt 7, Bild 1 von 1
    • Press slot pins outwards with gentle force.
  8. Asus K55a-si50301p RAM Replacement: Schritt 8, Bild 1 von 1
    • After the RAM stick pops up, pull it towards you to gently remove it.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 17
Insgesamt: 456
