Zum Hauptinhalt wechseln
Asus L410MA-MH09-CA Keyboard Replacement
Was du brauchst
    1. Asus L410MA-MH09-CA Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
      • Remove all ten 6 mm Phillips #1 screws that secure the lower case.
      • Insert an opening pick in the gap between the lower case and chassis.
      • Slide the opening pick around the entire perimeter of the laptop until the lower case fully releases.
      • Remove the lower case.
      Frag FixBot
      Kommentar hinzufügen
    2. Asus L410MA-MH09-CA Keyboard Replacement: Schritt 2, Bild 1 von 1
      • Remove the 4 mm Phillips #1 screws that secure the battery.
      Frag FixBot
    3. Asus L410MA-MH09-CA Keyboard Replacement: Schritt 3, Bild 1 von 1
      • Grip the white battery connector and pull it directly out of its battery port.
      Frag FixBot
    4. Asus L410MA-MH09-CA Keyboard Replacement: Schritt 4, Bild 1 von 1
      • Lift the battery out carefully.
      Frag FixBot
    1. Asus L410MA-MH09-CA Keyboard Replacement, Keyboard: Schritt 5, Bild 1 von 1
      • Use a Phillips #1 screwdriver to remove the screws that secure the hinges.
      • Lift the hinges up and out.
      Frag FixBot
    2. Asus L410MA-MH09-CA Keyboard Replacement: Schritt 6, Bild 1 von 2 Asus L410MA-MH09-CA Keyboard Replacement: Schritt 6, Bild 2 von 2
      • Disconnect the battery and display connectors.
      Frag FixBot
    3. Asus L410MA-MH09-CA Keyboard Replacement: Schritt 7, Bild 1 von 3 Asus L410MA-MH09-CA Keyboard Replacement: Schritt 7, Bild 2 von 3 Asus L410MA-MH09-CA Keyboard Replacement: Schritt 7, Bild 3 von 3
      • Remove the four 4 mm Phillips #1 screws that secure the heatsink.
      • Remove the heatsink.
      • Remove the remaining two 4 mm Phillips #1 screws that secure the motherboard.
      • Remove the motherboard.
      Frag FixBot
    4. Asus L410MA-MH09-CA Keyboard Replacement: Schritt 8, Bild 1 von 1
      • Use a spudger to pry around the entire perimeter of the metal bracket until it fully releases.
      • Remove the metal bracket.
      Frag FixBot
    5. Asus L410MA-MH09-CA Keyboard Replacement: Schritt 9, Bild 1 von 2 Asus L410MA-MH09-CA Keyboard Replacement: Schritt 9, Bild 2 von 2
      • Carefully disconnect the wide blue ribbon cable.
      • Remove the keyboard.
      Frag FixBot
Abschluss
Take your e-waste to an R2 or e-Stewards certified recycler.m
Jimmy
361 Reputation
3 Anleitungen geschrieben
Gateway, Team 8-2, Gonzalez Fall 2024 Mitglied von Gateway, Team 8-2, Gonzalez Fall 2024
GCC-GONZALEZ-F24S8G2
5 Mitglieder
24 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 32
Insgesamt: 542
