Zum Hauptinhalt wechseln
Asus L410MA-MH09-CA Speakers Replacement
Was du brauchst
  1. Asus L410MA-MH09-CA Speakers Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove all ten 6 mm Phillips #1 screws that secure the lower case.
    • Insert an opening pick in the gap between the lower case and chassis.
    • Slide the opening pick around the entire perimeter of the laptop until the lower case fully releases.
    • Remove the lower case.
  2. Asus L410MA-MH09-CA Speakers Replacement: Schritt 2, Bild 1 von 1
    • Remove the 4 mm Phillips #1 screws that secure the battery.
  3. Asus L410MA-MH09-CA Speakers Replacement: Schritt 3, Bild 1 von 1
    • Grip the white battery connector and pull it directly out of its battery port.
  4. Asus L410MA-MH09-CA Speakers Replacement: Schritt 4, Bild 1 von 1
    • Lift the battery out carefully.
  5. Asus L410MA-MH09-CA Speakers Replacement, Speakers: Schritt 5, Bild 1 von 1
    • Remove any electrical tape and disconnect any ribbon cables in the way.
    • They are there to secure the speaker wire in place.
    • Pull the white speaker connector directly out of its port.
  6. Asus L410MA-MH09-CA Speakers Replacement: Schritt 6, Bild 1 von 1
    • Lift the speakers out of the device.
Abschluss
After removing the speakers, you can install the replacement. To reassemble your device, follow these instructions in reverse order.
Jimmy
331 Reputation
3 Anleitungen geschrieben
Gateway, Team 8-2, Gonzalez Fall 2024 Mitglied von Gateway, Team 8-2, Gonzalez Fall 2024
GCC-GONZALEZ-F24S8G2
5 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 13
Letzte 30 Tage: 17
Insgesamt: 55
