Zum Hauptinhalt wechseln
Inhaltsverzeichnis
Von Studierenden verfasstes Wiki
Ein tolles Team von Studierenden aus unserem Bildungsprogramm hat dieses Wiki erstellt.
If your Asus L410MA-MH09-CA has no speaker output or no volume when playing media, follow this troubleshooting guide.
Keyboard mute key is toggled
It’s always a good idea to check the easy fixes, so before we confirm that the sound is not functioning properly, follow these steps.
  • Ensure volume is up, Make sure your device is not muted, look for volume controls on your keyboard or device.
  • If you’re unable to verify by using the keyboard buttons, check by using the volume control in the bottom left corner of the screen, next to the time.
Verify the output device
  • Make sure you have set the correct output device, You can check this by Start>Settings>system>sound.
  • Under output, click the drop down find the correct output that is connected to your device
  • Make sure your output volume slider is up and not muted.
Update audio drivers
  • Type "device manager" in the taskbar's search box, Select Device Manager.
  • Expand Sound, video and game controllers, Right-click the audio card you want to update
  • Select Update driver, Select Search automatically for updated driver software
Jordan Westby
309 Reputation
0 Anleitungen geschrieben
Gateway, Team 8-2, Gonzalez Fall 2024 Mitglied von Gateway, Team 8-2, Gonzalez Fall 2024
GCC-GONZALEZ-F24S8G2
5 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 27
