Einleitung
You will learn how to replace the SIM card reader. Review this guide if you are having difficulties with the SIM card reader. In order to replace the SIM card reader, you have to remove the battery. Please use our Asus MeMO Pad HD 8 ME180A Battery Replacement Guide to do so prior to starting.
Was du brauchst
Use a plastic opening tool to separate the back half from the front half.
Pull the back panel away from the device.
Ensure that you are wearing your Anti-Static Wrist Strap.
Using your spudger, press down on the two spots shown in order to release the cables.
Ensure that the touchscreen cables are fully disconnected.
Using a PH#0 screwdriver, remove the twelve silver 3.2 mm screws.
Pull the battery out.
Use a PH#0 screwdriver to unscrew the six 3.0 mm black screws.
Lift the motherboard straight up to remove.
Upon removal of the motherboard, desolder the pins that hold the SIM card reader in place.
Using a pair of tweezers, if desired, pull the sim card straight out.
