Einleitung
Be sure is it not the disk that is faulty before replacing the disk drive. If you are having anyother problems with this device check the troubleshooting page here.
Was du brauchst
Start by removing the 10 screws on the back of the laptop with a Phillips head 1 screw driver.
Remove back cover.
the battery must be removed so there is no power running to the disk drive. Follow the battery replacement guide here.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
