Zum Hauptinhalt wechseln
Asus ROG G55VW-DH71 Camera Replacement
Was du brauchst
  1. Asus ROG G55VW-DH71 Camera Replacement, Camera: Schritt 1, Bild 1 von 2 Asus ROG G55VW-DH71 Camera Replacement, Camera: Schritt 1, Bild 2 von 2
    • Using your iFixit opening tool, separate the frame by gently prying the two seams apart without completely removing the plastic frame piece.
    Frag FixBot
    Kommentar hinzufügen
  2. Asus ROG G55VW-DH71 Camera Replacement: Schritt 2, Bild 1 von 1
    • Once the frame is separated from the screen you will see the camera located in the top middle of the computer.
    • Using your iFixit opening tool, push the camera forward from behind, popping it out.
    Frag FixBot
  3. Asus ROG G55VW-DH71 Camera Replacement: Schritt 3, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Once the camera is accessible you will see it is connected to the laptop by a small wire that is clipped into the camera.
    • Using tweezers, gently pinch each side of the clipped in attachment that is connected to the camera to separate the computers wire from the old camera.
    Frag FixBot
Abschluss
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 11
Letzte 30 Tage: 55
Insgesamt: 698
