Zum Hauptinhalt wechseln
Asus ROG G55VW-DH71 RAM Replacement
Was du brauchst
  1. Asus ROG G55VW-DH71 RAM Replacement, RAM: Schritt 1, Bild 1 von 1
    • Flip the device over so that the bottom of the computer is easily accessible.
    • Using the Phillips size 0 head screwdriver, remove both 3.6mm. screws on the back plate located on the bottom left portion of the back of the laptop.
  2. Asus ROG G55VW-DH71 RAM Replacement: Schritt 2, Bild 1 von 1
    • Lift up and remove the back plate from the device.
  3. Asus ROG G55VW-DH71 RAM Replacement: Schritt 3, Bild 1 von 1
    • Gently pry apart the two white clips, that are holding in the RAM cards in, outwards.
  4. Asus ROG G55VW-DH71 RAM Replacement: Schritt 4, Bild 1 von 1
    • Lift then gently pull out the RAM card.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 656
