Zum Hauptinhalt wechseln
Asus ROG G751JL-BSI7T28 Fan Replacement
Was du brauchst
  1. Asus ROG G751JL-BSI7T28 Fan Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • With the laptop closed, turn it upside-down so the bottom is facing up toward you.
  2. Asus ROG G751JL-BSI7T28 Fan Replacement: Schritt 2, Bild 1 von 3 Asus ROG G751JL-BSI7T28 Fan Replacement: Schritt 2, Bild 2 von 3 Asus ROG G751JL-BSI7T28 Fan Replacement: Schritt 2, Bild 3 von 3
    • Place a spudger into the notch, and pry the small triangular piece away from the laptop.
    • Using a Phillips #00 screwdriver, remove the single 3 mm screw.
    • Place a spudger beneath the back panel and pry it away from the laptop.
  3. Asus ROG G751JL-BSI7T28 Fan Replacement, Display Assembly: Schritt 3, Bild 1 von 2 Asus ROG G751JL-BSI7T28 Fan Replacement, Display Assembly: Schritt 3, Bild 2 von 2
    • Remove all 5mm Phillips #00 screws from the back cover.
  4. Asus ROG G751JL-BSI7T28 Fan Replacement: Schritt 4, Bild 1 von 2 Asus ROG G751JL-BSI7T28 Fan Replacement: Schritt 4, Bild 2 von 2
    • Use a spudger to pry the disc drive out of the laptop.
  5. Asus ROG G751JL-BSI7T28 Fan Replacement: Schritt 5, Bild 1 von 3 Asus ROG G751JL-BSI7T28 Fan Replacement: Schritt 5, Bild 2 von 3 Asus ROG G751JL-BSI7T28 Fan Replacement: Schritt 5, Bild 3 von 3
    • Open the laptop and turn it so that the ASUS logo is facing you.
    • Gently lift up the display hinge housing shroud, but don’t pull it completely away yet.
    • Disconnect the RGB light power cable in the shroud, now the shroud can be put aside.
  6. Asus ROG G751JL-BSI7T28 Fan Replacement: Schritt 6, Bild 1 von 3 Asus ROG G751JL-BSI7T28 Fan Replacement: Schritt 6, Bild 2 von 3 Asus ROG G751JL-BSI7T28 Fan Replacement: Schritt 6, Bild 3 von 3
    • Remove the 5mm Phillips #00 screws.
    • Lift up the silver hinge brackets on each side of the laptop.
  7. Asus ROG G751JL-BSI7T28 Fan Replacement: Schritt 7, Bild 1 von 2 Asus ROG G751JL-BSI7T28 Fan Replacement: Schritt 7, Bild 2 von 2
    • Remove the 5mm Phillips #00 screws from the hinges.
    • Detach the ribbon cable and remove the display assembly from the laptop.
  8. Asus ROG G751JL-BSI7T28 Fan Replacement, Keyboard Assembly: Schritt 8, Bild 1 von 2 Asus ROG G751JL-BSI7T28 Fan Replacement, Keyboard Assembly: Schritt 8, Bild 2 von 2
    • Carefully lift the keyboard up, being careful to not damage the fragile ribbon connectors.
    • Use an opening tool to detach the ribbon cables connecting the keyboard to the rest of the laptop.
    • Remove the keyboard from the laptop.
  9. Asus ROG G751JL-BSI7T28 Fan Replacement, Fan: Schritt 9, Bild 1 von 2 Asus ROG G751JL-BSI7T28 Fan Replacement, Fan: Schritt 9, Bild 2 von 2
    • Remove the fan's power cable by pulling carefully outward towards the fan.
  10. Asus ROG G751JL-BSI7T28 Fan Replacement: Schritt 10, Bild 1 von 3 Asus ROG G751JL-BSI7T28 Fan Replacement: Schritt 10, Bild 2 von 3 Asus ROG G751JL-BSI7T28 Fan Replacement: Schritt 10, Bild 3 von 3
    • Remove the 5mm Phillips #00 screw.
    • Pull up on the black tab connected to the fan. This will pull it away from the cooling fins, allowing it to be removed.
    • Remove the fan from the laptop.
Abschluss
Kristen Gismondi
92.093 Reputation
241 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
118 Mitglieder
19.455 Anleitungen geschrieben
Ein Kommentar
What's the fan model?
Andres Landazuri - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 823
