Zum Hauptinhalt wechseln
Asus ROG GL551J Screen Replacement
Was du brauchst
  1. Asus ROG GL551J Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Lay the device on a flat surface with the battery facing up.
    • Be sure to wear ESD or Rubber gloves to protect the computer components.
  2. Asus ROG GL551J Screen Replacement: Schritt 2, Bild 1 von 1
    • Push the latch found below the battery to the unlock position.
  3. Asus ROG GL551J Screen Replacement: Schritt 3, Bild 1 von 1
    • Pull the battery out.
  4. Asus ROG GL551J Screen Replacement, Screen: Schritt 4, Bild 1 von 2 Asus ROG GL551J Screen Replacement, Screen: Schritt 4, Bild 2 von 2
    • Use a plastic opening tool to remove the plastic hinge covers on either side of the laptop.
  5. Asus ROG GL551J Screen Replacement: Schritt 5, Bild 1 von 2 Asus ROG GL551J Screen Replacement: Schritt 5, Bild 2 von 2
    • Remove the middle screws located on either side of the display.
  6. Asus ROG GL551J Screen Replacement: Schritt 6, Bild 1 von 2 Asus ROG GL551J Screen Replacement: Schritt 6, Bild 2 von 2
    • Use a plastic opening tool to pop out the bezel from all four sides, then lift it out of the frame.
    • When doing this in reverse during reassembly, try closing the laptop and applying pressure to reattach the bezel snaps.
  7. Asus ROG GL551J Screen Replacement: Schritt 7, Bild 1 von 1
    • Remove the screws at each corner of the display.
  8. Asus ROG GL551J Screen Replacement: Schritt 8, Bild 1 von 2 Asus ROG GL551J Screen Replacement: Schritt 8, Bild 2 von 2
    • Remove the connector from the display by pulling the wire downwards.
    • Be sure to take note of the orientation of the connector when unplugging and plugging in.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Thien Vu
412 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 5-4, Lacy Spring 2017 Mitglied von USF Tampa, Team 5-4, Lacy Spring 2017
USFT-LACY-S17S5G4
4 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
Hey, I am having issues putting the plastic hinge caps back on after I'm done. I know there is a right one and a left one but I just don't know how to pop them back into place. Starting to get a bit desperate. Could anyone give me some tips?
Thanks!
Teodor Andonov - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 14
Insgesamt: 3,185
