Einleitung
Your battery seems like it does not charge? It may be time to replace it. This guide will provide a step by step walk through to access and replace your Asus UL30VT-A1 battery. To troubleshoot your device battery first check the link below.
Flip the laptop so that you can see the back part. (As shown on the image)
Identify both slide locks.
Slide both towards the unlocked lock.
Make sure you can see the red mark that indicates it is unlocked. (See image number two)
Finally, while unlocking the right lock pull the battery. (See Image number two)
The battery should slide out of place.
Eine weitere Person hat diese Anleitung absolviert.
