Zum Hauptinhalt wechseln
Asus VivoBook Max X541UV-BH71-CB Battery Replacement
Was du brauchst
  1. Asus VivoBook Max X541UV-BH71-CB Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the laptop upside down so the back of the laptop faces you.
  2. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: Schritt 2, Bild 1 von 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: Schritt 2, Bild 2 von 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: Schritt 2, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove the ten 1.2 mm screws attached to the back cover of the laptop.
  3. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: Schritt 3, Bild 1 von 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: Schritt 3, Bild 2 von 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: Schritt 3, Bild 3 von 3
    • Turn the laptop upright, then open the laptop so the screen faces you.
    • Use a prying tool between the keyboard and bottom grooves to partially remove the laptop backing.
    • Do not completely remove the laptop backing because there are ribbon cables connecting the two halves.
    • It is recommended to use a plastic prying tool rather than a metal prying tool because it could potentially damage the internals of the laptop.
  4. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: Schritt 4, Bild 1 von 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: Schritt 4, Bild 2 von 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: Schritt 4, Bild 3 von 3
    • Flip the retaining flaps on both keyboard ribbon cable ZIF sockets, then carefully pull the ribbon cables out of their sockets.
    • Carefully remove the keyboard panel from the base and set it aside.
  5. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: Schritt 5, Bild 1 von 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: Schritt 5, Bild 2 von 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: Schritt 5, Bild 3 von 3
    • Remove the two 1.2 mm screws holding the battery in place using the Phillips #00 screwdriver.
  6. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: Schritt 6, Bild 1 von 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: Schritt 6, Bild 2 von 3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: Schritt 6, Bild 3 von 3
    • Carefully remove the battery using a plastic opening tool.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Vivek Rana
169 Reputation
1 Anleitung geschrieben
York University, Team E-23, Melo-Thaiss Fall 2021 Mitglied von York University, Team E-23, Melo-Thaiss Fall 2021
YORK-MELO-THAISS-F21SEG23
1 Mitglied
1 Kommentar zur Anleitung
Does anybody has a link to buy the battery replacement? Either original or generic. Thank you!
nea-k nanea - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 16
Letzte 30 Tage: 50
Insgesamt: 3,114
