Einleitung
In this guide you will learn how to replace your Asus Vivobook X540SA-BPD0602V battery. Batteries should be replaced every couple of years because over time, they will fail to hold a charge. All power sources, including the battery, should be removed before completing any repairs or replacements within the device.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Was du brauchst
Power down the laptop using the device's power button in top right corner of the keyboard. Ensure that the device's power cord is disconnected.
Using a Phillips #1 screwdriver, remove the ten screws from the back panel.
Remove the two battery screws (15.6 mm)
Two top corner screws (12.5 mm)
Six case screws (9.7mm)
Using the blue plastic opening tool, wedge and loosen the seal all the way around the edges. Carefully lift up the keyboard panel.
Observe where the ribbons connect to the motherboard, there are two connections. Each connection has a black clamp. To remove the ribbon, lift the black clamp up to disconnect it.
Very carefully, remove the batteries with the blue plastic iFixit opening tool. Focus removing the battery near the highlighted area.
3 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Easy, and nice guide.
To be honest you don't need make pint 6 - unplug keyboard and pad cable. You can just move cover a bit to your side (pull into your direction) then you will get a lot space to pull out battery.
