Zum Hauptinhalt wechseln
Asus Vivobook Max X541SA-PD0703X CD drive Replacement
Was du brauchst
  1. Asus Vivobook Max X541SA-PD0703X CD drive Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • Flip the laptop upside down so that the back of the laptop faces you.
  2. Asus Vivobook Max X541SA-PD0703X CD drive Replacement: Schritt 2, Bild 1 von 1
    • Remove the following ten Phillips #0 screws from the bottom of the laptop:
    • Six 13mm screws.
    • Four 11mm screws.
  3. Asus Vivobook Max X541SA-PD0703X CD drive Replacement: Schritt 3, Bild 1 von 3 Asus Vivobook Max X541SA-PD0703X CD drive Replacement: Schritt 3, Bild 2 von 3 Asus Vivobook Max X541SA-PD0703X CD drive Replacement: Schritt 3, Bild 3 von 3
    • Using a plastic opening tool, pry up the palm rest from the bottom case of the laptop.
    • Don't completely remove as there are ribbon cables connecting the two halves.
  4. Asus Vivobook Max X541SA-PD0703X CD drive Replacement: Schritt 4, Bild 1 von 3 Asus Vivobook Max X541SA-PD0703X CD drive Replacement: Schritt 4, Bild 2 von 3 Asus Vivobook Max X541SA-PD0703X CD drive Replacement: Schritt 4, Bild 3 von 3
    • Use a spudger to flip up the retaining flaps on both keyboard ribbon cable ZIF sockets.
    • Pull the ribbon cables out of their sockets.
  5. Asus Vivobook Max X541SA-PD0703X CD drive Replacement: Schritt 5, Bild 1 von 1
    • Remove the three 6mm Phillips #0 screws from the motherboard.
  6. Asus Vivobook Max X541SA-PD0703X CD drive Replacement: Schritt 6, Bild 1 von 2 Asus Vivobook Max X541SA-PD0703X CD drive Replacement: Schritt 6, Bild 2 von 2
    • Pull the Wi-Fi card out of the motherboard.
  7. Asus Vivobook Max X541SA-PD0703X CD drive Replacement: Schritt 7, Bild 1 von 1
    • Remove the hard drive by pulling it towards the right, and removing it from the laptop case
  8. Asus Vivobook Max X541SA-PD0703X CD drive Replacement, Disc Drive: Schritt 8, Bild 1 von 1
    • Remove the disc drive by sliding it towards the right and removing it from the laptop case
Abschluss
USF Tampa, Team S1-G4, Cagle Spring 2018 Mitglied von USF Tampa, Team S1-G4, Cagle Spring 2018
USFT-CAGLE-S18S1G4
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 16
Insgesamt: 760
