Einleitung
A hard drive is an essential part of the laptop which is needed in order to store data. This guide will show you how to replace the battery of your Asus Vivobook Max X541SA-PD0703X.
Was du brauchst
Flip the laptop upside down so that the back of the laptop faces you.
Remove the following ten Phillips #0 screws from the bottom of the laptop:
Six 13mm screws.
Four 11mm screws.
Using a plastic opening tool, pry up the palm rest from the bottom case of the laptop.
Use a spudger to flip up the retaining flaps on both keyboard ribbon cable ZIF sockets.
Pull the ribbon cables out of their sockets.
Remove the hard drive by pulling it towards the right, and removing it from the laptop case
3 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Thanx a million
is it possible to upgrade the hard drive of any laptop? from 500GB to 1T?
