Zum Hauptinhalt wechseln
Asus Vivobook Max X541SA-PD0703X Track Pad Replacement
Was du brauchst
  1. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Flip the laptop upside down so that the back of the laptop faces you.
  2. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: Schritt 2, Bild 1 von 1
    • Remove the following ten Phillips #0 screws from the bottom of the laptop:
    • Six 13mm screws.
    • Four 11mm screws.
  3. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: Schritt 3, Bild 1 von 2 Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: Schritt 3, Bild 2 von 2
    • Using a plastic opening tool, pry up the palm rest form the bottom half of the laptop.
    • Ribbon cables connect the two half so don't remove completely.
  4. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: Schritt 4, Bild 1 von 3 Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: Schritt 4, Bild 2 von 3 Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: Schritt 4, Bild 3 von 3
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF sockets.
    • Pull the ribbon cables out of their sockets.
  5. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: Schritt 5, Bild 1 von 1
    • Take the keyboard half of the laptop and place it in front of you so that they keys are facing down.
  6. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: Schritt 6, Bild 1 von 1
    • Remove the three 3mm Phillips #0 screws from the touchpad.
  7. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: Schritt 7, Bild 1 von 1
    • Use a spudger to flip up the retaining flap on the touch pad ribbon cable ZIF socket.
    • Pull the ribbon out of the socket.
  8. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: Schritt 8, Bild 1 von 2 Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: Schritt 8, Bild 2 von 2
    • Remove the touchpad.
Abschluss
Hetvi Mehta
781 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S1-G4, Cagle Spring 2018 Mitglied von USF Tampa, Team S1-G4, Cagle Spring 2018
USFT-CAGLE-S18S1G4
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 479
