Zum Hauptinhalt wechseln
Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement
Was du brauchst
  1. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Make sure the computer is turned off.
    • Flip the device over so that the back cover is facing you.
  2. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: Schritt 2, Bild 1 von 2 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Remove the four 5mm Phillips #1 screws from the top of the laptop.
    • Remove the two 6mm Phillips #1 screws from the sides of the laptop.
    • Remove the four 2mm Phillips #1 screws from the bottom of the laptop.
  3. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: Schritt 3, Bild 1 von 3 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: Schritt 3, Bild 2 von 3 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
  4. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Lift off the cover and remove the back cover from the device.
  5. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement, Battery: Schritt 5, Bild 1 von 2 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement, Battery: Schritt 5, Bild 2 von 2
    • Using a Phillips #1 Screwdriver remove the six 3 mm screws keeping the battery in place.
  6. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: Schritt 6, Bild 1 von 2 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Unplug the battery connector from the mother board.
  7. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: Schritt 7, Bild 1 von 2 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Gently remove the battery from the slot.
  8. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement, Wifi card: Schritt 8, Bild 1 von 3 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement, Wifi card: Schritt 8, Bild 2 von 3 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement, Wifi card: Schritt 8, Bild 3 von 3
    • Unplug the two small cords connected to the wifi card.
  9. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Using a Phillips #1 Screwdriver unscrew the 2 mm screw holding the wifi card in place.
  10. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: Schritt 10, Bild 1 von 3 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: Schritt 10, Bild 2 von 3 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: Schritt 10, Bild 3 von 3
    • Unplug the Wi-Fi card from the motherboard and remove it from the device.
  11. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement, Fan and Heatsink: Schritt 11, Bild 1 von 3 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement, Fan and Heatsink: Schritt 11, Bild 2 von 3 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement, Fan and Heatsink: Schritt 11, Bild 3 von 3
    • Using a Phillips #1 Screwdriver remove the three 3 mm black screws and four 2 mm copper screws holding the fan and heat sink in place.
  12. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: Schritt 12, Bild 1 von 2 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: Schritt 12, Bild 2 von 2
    • Remove the wire connecting the fan to the motherboard.
  13. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: Schritt 13, Bild 1 von 2 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: Schritt 13, Bild 2 von 2
    • Gently remove the fan and heat sink from the motherboard.
    • On reassembly, be sure to clean the CPU and heat sink and reapply thermal compound to the CPU. Follow this guide to learn how.
  14. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement, RAM: Schritt 14, Bild 1 von 3 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement, RAM: Schritt 14, Bild 2 von 3 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement, RAM: Schritt 14, Bild 3 von 3
    • Remove the top covering the RAM chips.
  15. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: Schritt 15, Bild 1 von 3 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: Schritt 15, Bild 2 von 3 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: Schritt 15, Bild 3 von 3
    • Gently push the RAM chip holder to the sides.
  16. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: Schritt 16, Bild 1 von 3 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: Schritt 16, Bild 2 von 3 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: Schritt 16, Bild 3 von 3
    • Remove the RAM from the device.
  17. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement, Motherboard: Schritt 17, Bild 1 von 1
    • Remove the four 4.0 mm Phillips #1 screws shown.
    • Remove the two 5.0 mm Phillips #1 screws shown.
    • Remove the three 3.0 mm Phillips #1 screws shown.
  18. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: Schritt 18, Bild 1 von 2 Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: Schritt 18, Bild 2 von 2
    • Using a plastic opening tool, pry open the hinge shown until your fingers can fit under it.
    • Pull the hinge the rest of the way up.
  19. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: Schritt 19, Bild 1 von 1
    • Disconnect the motherboard from the two connectors shown.
  20. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: Schritt 20, Bild 1 von 1
    • Disconnect the motherboard from the connector shown.
  21. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: Schritt 21, Bild 1 von 1
    • Pull the motherboard loose.
  22. Asus Vivobook Q301LA-BHI5T02 Motherboard Replacement: Schritt 22, Bild 1 von 1
    • Disconnect the motherboard from the connector shown and it is now removed from your device.
Abschluss
Caleb Ellis
133 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S5-G3, Gulbrandsen Fall 2018 Mitglied von UMass Dartmouth, Team S5-G3, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G3
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 491
