Zum Hauptinhalt wechseln
Asus X551CA Hard Drive Replacement
Was du brauchst
    1. Asus X551CA Hard Drive Replacement, Keyboard Plate Cover: Schritt 1, Bild 1 von 1
      • Power off and unplug your laptop before you begin.
      • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
      • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
      • Two 4.3 mm screws in the back corners
      • One 17.5 mm screw at the left edge near the optical drive
      • Three 4.3 mm screws in the front edge
      Frag FixBot
      Kommentar hinzufügen
    2. Asus X551CA Hard Drive Replacement: Schritt 2, Bild 1 von 1
      • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
      Frag FixBot
    3. Asus X551CA Hard Drive Replacement: Schritt 3, Bild 1 von 1
      • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
      Frag FixBot
    4. Asus X551CA Hard Drive Replacement: Schritt 4, Bild 1 von 3 Asus X551CA Hard Drive Replacement: Schritt 4, Bild 2 von 3 Asus X551CA Hard Drive Replacement: Schritt 4, Bild 3 von 3
      • Invert the laptop in order to gain access to the ribbons.
      • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
      Frag FixBot
    5. Asus X551CA Hard Drive Replacement: Schritt 5, Bild 1 von 1
      • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
      Frag FixBot
    1. Asus X551CA Hard Drive Replacement, Hard Drive: Schritt 6, Bild 1 von 1
      • Unscrew the three 5.5 mm Phillips #0 screws with the Phillips #0 Screwdriver.
      Frag FixBot
    2. Asus X551CA Hard Drive Replacement: Schritt 7, Bild 1 von 1
      • Once the screws have been removed, place your fingers on the left corners and push the hard drive towards the right edge of the laptop (relative to the picture).
      Frag FixBot
    3. Asus X551CA Hard Drive Replacement: Schritt 8, Bild 1 von 1
      • Once it is free, remove the hard drive from its internal cavity.
      Frag FixBot
Abschluss
48 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 7-22, Regan Spring 2014 Mitglied von Cal Poly, Team 7-22, Regan Spring 2014
CPSU-REGAN-S14S7G22
5 Mitglieder
160 Anleitungen geschrieben
8 Kommentare zur Anleitung
You mixed up the red and green screws, sizes are wrong.
The red screws are 9.5 not 14.3!
the yellow screws are 4.3 (mixed up with 14.3 ?) not 9.5 !
You do NOT need to remove the ribbons, just use a small screwdriver.
Tony - Antwort Teilen
Excellent work !
Drew Lawrence - Antwort Teilen
Same issue as Tony on 09/03/2014
The screw sizings are mixed up. The red screws are 9.5, not 14.3
The yellow screws are 14.3 not 9.5. Please fix the repair guide text
Mevlan Coma - Antwort Teilen
It should be fixed now! Thanks to both of you for the tip. By the way, you can always edit the text yourself. ;)
Jeff Suovanen - Antwort Teilen
Thanks for the info!
Abe Aleman - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 16
Letzte 30 Tage: 73
Insgesamt: 68,034
