Einleitung
If you are having trouble with your Asus X553MA-BPD07051 running very slow or giving you the Blue Screen of Death, check what the RAM is running at. If it is running at 40% or higher, your RAM should be replaced. For additional information, check out this troubleshooting page. Use this page to assist you in replacing your RAM. Before beginning, make sure that the laptop has been turned off and battery removed first in order to avoid being shocked.
Was du brauchst
Use a Phillips #0 screwdriver (PH0 bit) to remove the four 5.0 mm screws that are securing the bottom of the laptop.
Use a Phillips #0 screwdriver (PH0 bit) to remove the six 11.0 mm screws that are securing the bottom of the laptop.
Lift the edges of the keyboard using the plastic iFixit opening tool and raise the keyboard slightly to see the inside of the laptop.
Lift back the clip on the ribbon tape, and pull the tape out in order to remove the keyboard from the laptop.
Remove both pieces of the ribbon tape connecting the keyboard to the motherboard.
Remove the bundled cable connector attaching the battery to the motherboard with the plastic iFixit opening tool.
Use Phillips #0 screwdriver (PH0 bit) to remove the four 6.0 mm screws attaching the battery to the laptop.
Use a Phillips #0 screwdriver (PH0 bit) to remove the four 6.0 mm screws that are securing the hard drive.
Lift the hard drive up and pull it towards the screen so that it disconnects from the motherboard.
Use a Phillips #0 screwdriver (PH0 bit) to remove the one 6.0 mm screw holding in the optical drive.
Remove the bundled cable connector that connects the fan to the motherboard using the plastic iFixit opening tool.
Remove the bundled cable connector that attaches the audio to the motherboard with the plastic iFixit opening tool.
Lift the metal clip holding the ZIF connector ribbon down.
Pull the ribbon out from the connector, away from the motherboard.
Use a Phillips #0 screwdriver (PH0 bit) to remove the five 6.0 mm screws attaching the motherboard to the base of the laptop.
Lift the metal clips holding the ZIF connector down.
Push the gold metal connector away from the motherboard.
Lift the coaxial connector from the wifi chip with the plastic iFixit opening tool.
Remove the RAM by lifting and pulling it up from the back of the motherboard.
2 weitere Personen haben diese Anleitung absolviert.
