Einleitung
This guide will show you how to replace an old worn out or dead battery in an Asus ZenBook UX303U laptop.
Was du brauchst
Pull the speaker cable out of its four retaining clips with either your fingers, or a plastic opening tool.
Pull the speaker connector toward the edge of the laptop to disconnect it from its socket.
Lift the battery connector straight up off its socket to disconnect it from the motherboard.
17 weitere Personen haben diese Anleitung absolviert.
11 Kommentare
hello where I can buy a UX303U battery for asus?
hello! Where I can buy a UX303U battery for my Asus netbook?
thanks
Just gone through this, but two problems surfaced. 1 it won’t connect to our usual WiFi router and can’t figure out why. Is it possible to damage the WiFi connectivity when removing battery? 2 there’s no indication of charge levels. It says 100% and doesn’t change. Thoughts?
Take all that back. Went back in and battery connector hadn’t clicked in far enough. Seems to be working fine now.
