Einleitung
If your Asus ZenBook UX330U or UX330UA cannot connect to Wi-Fi, then you may need to replace your Wi-Fi adapter. Before using this guide, look at the troubleshooting page located here for possible fixes that do not require any disassembly. This guide can be used to remove the Wi-Fi adapter for the ASUS ZenBook UX330U or UX330UA.
Before beginning any device disassembly, please power off and unplug your device.
Was du brauchst
Before starting any device dissasembly, please put on the anti-static bracelet provided by iFixit. Make sure the metal part of the bracelet is touching your skin.
Remove the alligator clip at the end of the bracelet by simply pulling it off, to reveal the bullet connector.
Insert the bullet connector into the ground port of an outlet.
Remove the eight 3.1mm screws using the T5 Torx screwdriver bit.
Remove the longer 5.1mm screw using the T5 Torx screwdriver bit.
Use a Jimmy or a spudger to pry off the two rubber feet that are closest to the hinge.
Unscrew the two 5.6mm screws that were underneath the rubber feet using the Philips #0 screwdriver bit.
Remove the four 2.8mm screws from the motherboard ribbon connector using the Philips #0 screwdriver bit.
Remove the motherboard ribbon connector by pulling up on the metal ends with the blunt nose tweezers.
Pull back the silver battery connector lock with the blunt nose tweezers. This should slide back and should require minimal force.
Lift the battery connector vertically using the blunt nose tweezers to remove it from the socket.
Disconnect the two UFL female connector cables by gently prying up with the blunt nose tweezers.
Remove the single 2.7 mm screw holding the Wi-Fi adapter using the Philips #0 screwdriver bit.
Gently grip the Wi-Fi adapter by the sides and pull it out with gentle pressure. You may need to slightly wiggle the adapter to get it to slide out easily.
